- Mar 1, 2010
Its described as "Electromagnetic Shutoff Valve". I therefore assume it must be some sort of solenoid. I've not heard of one failing. It would have to fail in the open position. I would think a spring closes the valve when electomagnetism is not on and therefore it would be foolproof especially if made by Bosh. When the engine runs on you could try cutting the electrical supply to the valve and the engine can't run on unless the valve is faulty.
As an aside, in the old days, petrol engines ran on due to hot carbon in the combustion chambers. The hot carbon acted as a sparking plug and petrol supply was maintained due to a mechanical pump run off the camshaft. Sometimes one would have to drop the clutch in gear to stop the engine.
