HELP Cruiser Not Starting :(
Jacob Todd
australia
Hey guys,
I've got a 75 series land cruiser that won't start. I turn the key and don't hear any 'click' of relays and also have no scatter lights on the dash light up. The radio works but that's it. I've checked the battery and fusible link coming off the battery and they both appear to be fine. Any ideas on what could be causing this?
Thanks a lot :)
I would double check fiseable links and fuses with a rest light make sure you e power both ends and their connections also
Also worth checking earth connections but sounds like a fuse somewhere
Checking connections if you have checked power like above and then look at the starter if not clicking.
Hi! Is it an auto? It might be the star inhibitor switch on the gearbox. If it's a manual, try to check the starter relay under the hood. It is located on the right side when you look at the engine bay.
You can try to clean them both, if it's necesary
DSCN0439.JPG DSCN0451.JPG Toyota-Landcruiser-Denso-Starter-Relay-28300-17030.jpg
