kombivan
- Oct 6, 2017
I have low oil pressure engine has done about 30,000k's since rebuild motor no idea how long its been low as its hidden behind the steering wheel the gauge. I have a 1986 dash in a 1982 cruiser, I intend replacing oil and filter after changing pressure relief valve and also checking the bypass valve I have a piston in the mail. I was also wondering if some one could post a photo of the relief valve and bypass valve so I know I'm unscrewing the correct item as the manual isn't that clear. The oil has been in my car for 2 years I think but only done about 1000k's as its been getting body work done bit by bit as a side job by a really nice Panel and paint guy. Great Lakes Panel and paint 0265556258 might be a distance away from you but he is good. So I need a couple of pictures and anything I have forgotten thank you Guys.
Back in 1999 when I first got her.
