hj60 springs
walesdale Feb 27, 2013
  1. walesdale
    walesdale New Member
    25
    0
    16
    Map
    hello people,i just fitted a set of standerd milner springs and shocks all round on my 60 and its awful
    its bouncing around everywhere , even with the tyre pressures down to 18 psi (31/10.5/15)
    does anyone know where i can get a nice set of springs that ride nice,thanks
  2. Seamus
    Seamus Active Member
    58
    1
    16
    Map
    Dale,
    I'm no expert on this but from what I've read new leaf springs aways feel hard for a while and soften up after some use.
    Hope this helps and look forward to see if you get any more information as I put a question asking what others had used and what is good still waiting for a reply on that.
    Mike.
  3. walesdale
    25
    0
    16
    Map
    cheers mike,ive about 1000 mile in it and it still wont give in,,thanks
  4. AndycruiserguyLomas
    3,630
    898
    113
    Map
    OME are pretty much a copy of the original design which is the best design for a 60 but expensive. Best ride can be achieved with a set of original springs,taken apart and each leaf shotblasted and painted. The top two leaves taken to a spring manufacturer and re tempered with a 1" re arch. With a flap wheel smooth any wear ridges out. Replace all the teflon cushions at the end of most leaves (still available from Toyota) and re assemble. The spring will pretty much resemble a new one. Original dampers are ok but Bilstien give a great ride with springs done up as above. Use original Toyota rubber bushes as they also give a better ride than poly bushes.
    hope this helps.
    Andy
    oding likes this.
  5. Seamus
    58
    1
    16
    Map
    Tony said you were the man to ask !!!
    Can you also lift on original springs? Iknow it is possible just wondering how they perform.
    Mike.
  6. AndycruiserguyLomas
    3,630
    898
    113
    Map
    Milner springs were made in Hell by the devil's blacksmith himself, guaranteed to be a back breaker on every speed bump. If you look at the design you can see they just won't work like an OEM does.
    Andy
  7. walesdale
    25
    0
    16
    Map
    Thanks andy
    Id like to catch hold of the devils blacksmith and take him for aride
  8. walesdale
    25
    0
    16
    Map
    I forgot to ask andy, does the bilstiens give a hard ride..? Thanks
  9. AndycruiserguyLomas
    3,630
    898
    113
    Map
    Sorry with the late reply Dale, Bilsteins give a great ride with good condition springs, no dampers will give a good ride with poor springs. Ask Tim here on the forum what is the ride quality on his full OME setup.
    Andy
  10. walesdale
    25
    0
    16
    Map
    Will do.tim if ur reading this.let me know.cheers
  11. priffe
    priffe New Member
    18
    0
    6
    Map
    Have some experience with springs but am no expert.
    My preference with a 60 series is not comfort but strength. Looking for a nice ride buy an 80 with coil springs.
    Leaf suspension means handling won't be great.
    Original six leaf suspension is too weak. Will sag when fully loaded, even worse for expedition.
    My buddy put in an OME medium suspension, surprisingly comfy ride, but also too weak.
    We've reformed and retempered old leaves but much prefer new steel.
    Or add at least two leaves, for the use we intend which means the roughest hardest offroad. In Sahara and elsewhere.
    They can go anywhere.
    But maybe there's no need for 11 or 14 leaves; I've seen newer cruisers with only six but much stronger leaves.
    For comfort, adding coils or coil conversion is probably a good idea. I haven't tried it yet.
  12. AndycruiserguyLomas
    3,630
    898
    113
    Map
    I've seen parabolic springs on a 40 series, maybe they are the answer as they combine strength with lightness and a good ride, anyone know if they are available for a 60?
    Andy
  13. iwan_t24
    iwan_t24 Well-Known Member I am in wales
    927
    411
    83
    Map
    The guys at L&L land cruisers in the netherlands have a set of 60 series parabolic springs for a 60 series on a pallet outside. I saw them when I was there over the new year. I have also seen them on 60's with SOA conversions in the USA (best country in the world!) They're around Andy
    Hey Priffe, diggin the 14 leaf rear springs you have there¬! I think I'm going to add a few more to mine now!
  14. kombivan
    kombivan New Member I am in australia
    25
    7
    3
    Map
    I know this is an old post The HJ60 G series have Highway springs specially designed for comfortable rides on the tar to lift a little and get more strength get a spare set of springs and rob the longest leaf and add it to your spring set each side this gives a better carrying capacity and also maintains the smooth ride and also get the springs reset at the same time and you'll have nice springs till the cows come home. Rubber are the best shackle bushes the eurthane don't last long at all few thousand K the rubber 100,000k I fitted rubber in mine in 2004 and their still good.
  15. moggy1968
    moggy1968 Well-Known Member
    2,007
    626
    113
    Map
    I've got OME heavy duty and they ride suprisingly well (As Andy Loamas will testify having had a ride in me truck! They don't like the british weather much and aren't cheap, but they do seem pretty good and offer good articulation flex max 2.jpg flex max.jpg
    AndycruiserguyLomas likes this.
  16. AndycruiserguyLomas
    3,630
    898
    113
    Map
    I agree, the rubber bushes are by far the best.
    Yep for a 60 yours does ride very well, that said it must weigh in considerably more than standard which helps.
  17. moggy1968
    2,007
    626
    113
    Map
    lol, only a little ;o) the HD springs are intended to have a permanent load of about 200Kg I think, from memory, which on the rear I probably don't have normally, certainly when I dropped in to see you I didn't have that much on board. It did worry me that I hadn't bedded them in properly because your supposed to carry a bit of weight when their new, which I didn't, but they don't seem to have suffered. The fronts are fairly loaded because of the winch and winch bar. I reckon for the Italy trip I just did I was total weight of well over 3 tons so yes, it did ride nice!! I reckon the rear dropped about 2 inches when fully loaded!!
  18. oding
    oding Well-Known Member I am in philippines
    423
    113
    63
    Map
    My suggestion, I use Kayaba single action shocks both front and rear. They do very well when you travel overland. You can download the catalog on this URL, http://www.technical-touch.com/downloads
    https://www.kyb.com/catalog/
  19. Ben Stratford
    Ben Stratford Well-Known Member Supporter I am in england
    1,460
    356
    83
    Map
    Moggy, which shocks did you fit with the ome springs?
    I’m looking to upgrade suspension soon having thought long and hard about it.
    Have decided that it will remain a standard vehicle so no extra weight at all unless a weekend camping trip is arranged.
    So want to fit soft springs and shocks. The ome set up is appealing. The new nitrocharger shocks sound good too
  20. AndycruiserguyLomas
    3,630
    898
    113
    Map
    Ben, by "upgrade" do you mean replace? You won't get a "wonder " ride with OME as they are a copy of the OEM ones.
    The only upgrade for a better ride would be 2 leaf parabolics
    I've had all the dampers you can think of on 60's, Rancho, OME, Bilstein, Koni, DeCobain and standard. With good standard springs I like Bilstein's and DeCobain but they are all decent.
Share This Page
    Dismiss Notice
