Alrightchief
- May 5, 2018
I've read in another forum about a Cherokee, that was modified, mostly the underbody, panels were added to specific spots to improve the aerodynamics. From the exterior the car looks like unmodified, but with these mods, the guy got improved it's fuel economy from ~19mpg to ~30mpg. He posted about the aerodynamic simulations he made and the test results. If you are interested, I can search that thread and post it here.
Other than that, I am planning to do the same for my J95 D4D, I will model the whole underbody and make a few flow simulations, and I will modify the sub according to the results. If you are interested, I will post the whole process with the model, pictures and test results...
In the engine oil I use Metalube, it smoothed out the engine, I also use Metalube fuel additive. I used this stuff on all my cars, I have several hundred thousand of experience with these products and I love it. I will put in my diffs also soon.
With my stock car, using the additives I get 28.34mpg traveling at 68miles/hour.
The car: J95 D4D 3.0
4 speedAutomatic transmission
265/70/R16 tyres
That is a point I have all my panels off at the moment so that's interesting! I also would be interested in seeing the research you conduct!
