LuckyStrike
- Jun 13, 2017
Hey guys,
I made a simple DIY tool that you can make for under $3 USD to grease your spindle bearings without messing with the wheel bearing lock nut, lock washer, or wheel bearing pre-load. This is great for annual services between wheel bearing repacks. The video is linked down below and it covers the entire process. The DIY tool lubricates the spindle bearing exactly the same as the slee tool besides the wheel bearing jam nut part. If you have any questions / comments let me know. Hope this helps you guys out.
