Rups Dhillon
- May 28, 2018
Hi All,
Has anyone had any experience with wheel spacers on a 100 series? I am trying to understand if a hub centric spacer will fit on the front hubs and allow the wheel to sit on the lip. I have heard on other forum threads (mainly in OZ and USA) that the rears will accommodate hub centric spacers but the front may be tricky because the hub protrudes through the centre.
Hub bore on a 100 series is 110mm and the wheels I am now running are having 116.5mm wheel bore. This is causing steering vibration at 60-70mph. I can get hold of custom made hub centric spacers (expensive) but would like some of your opinions on the front hub fitment.
p.s. I have tried to source spigot rings but they are simply not available for the sizes 116.5 - 110. Neither can they be custom made apparently!
Thanks,
Rups
100 Series 1HDFTE, 4.2TD (2004)
Thanks,
Rups
