- Feb 2, 2013
Yeah i meant is it better or worse for the radio , if it doesn't work this time i swear i will huff and i will puff and ......... sit in a corner and cwy .
I am basically just running a 17 amp wire from the spare wheel carrier to chassis , assuming it doesn't matter a damn if the door is ground or not then .
But because its coming through the door into the jack cubby and out through the floor to chassis , i was thinking why not split it and bolt it to the body inside the cubby as well .
In truth i can't see how it matters either way but that said i can find no reason at all my cb has never worked
