Rob
This weekend my speedometer has developed a fault. It started out by not working at all while driving around the farm track at Lincomb, and then started working after going over some potholes. On the motorway on the way back it worked most of the time but occasionally it was intermittent and the needle was jumping a lot, seemed to be affected by acceleration/deceleration which makes me think its a loose connection. I have looked at the connection on the transfer case and it seems fine. Is there an easy way to diagnose the fault? Where can I check for the speedometer signal apart from on the back of the instrument panel?
