Ironman 4x4 Foam Cell Pro Shocks
WestCoastOffRoad
Land Cruiser Club sponsor
Promoted Company
They’re finally here! Ironman 4×4 Foam Cell Pro Shocks are now available for the first time in the UK.
The Foam Cell Pro shocks use thicker material, stronger welds and state of the art fabrication, meaning they are built to last. The shocks use the largest body size available, meaning they can hold 3 times the amount of oil than most other shocks. Therefore the Foam Cell Pro shocks will take more abuse for longer, due to the fact that they resist heat build up like no other standard 4×4 shock.
Just like other ironman shocks, the Foam Cell Pro is a completely bolt on peice of kit. Designed to fit a large range of both standard and lifted 4×4’s whilst being fully re-buildable and remaining affordable, makes the Foam Cell Pro the best shock available in the UK.
Ironman 4x4 challenges 4x4 owners to compare Foam Cell Pro with all other brands. The Ironman 4x4 Foam Cell Pro features include:
• 65-72mm outer body
• 45mm diameter piston
• 20mm chrome hardened piston rod
• 3mm exterior tube thickness
• 360 degree welded mounts
• Rebuildable design
• Threaded height adjustable strut spring seat
• Integrated bump stop (on applicable models)
• Single piece solid mounting base
• Solid one piece eye ring
• Twin Tube Construction
• Foam Cell Design
• 3 year / 60,000km Ironclad Warranty
*Contact us for price and availability*
Take a look at westcoastoffroad.co.uk
