Iwan
- Mar 28, 2011
Im Enjoying this.... Crack on Iwan!
Cheers mate! It's a bit like an adventure really. Been a good way to learn and essentially a way to keep the mind occupied. I basically really like the truck and haven't seen one with the JDM originality quite like it recently.. it has it's problems and some rust issues.
By the way of it's appearance it is worth attention and look forward in getting some use out of it. I'm sure with a good few hours of work as with your 12v it will hit the road again!
Have the valves out of it and have been cleaning up the head. Quite surprised this morning to wake up to 3 inches of snow here and it's November the 9th! Was strange how the leaves are on the trees, never seen that before!
Exhaust valves are in (dire) need of grinding in and if they're loose in the guide.
The fsm says to check the springs for squareness and if they're 2mm out to renew. Found out that in the north south axis they're square and the other axis are not so square! Something is telling me that you shouldn't trust the odometer on an import! Lol
Had a hell of a good load in the back of my 81 today! 20 x 25kg bags of coal and a 19kg gas cylinder! Drove as normal and looked like it had a heavy trailer on the back! Snow driving and when the lsd kicked in it liked to drive straight! A bit light on the front to say the least!
