J90 D4D - Mounting an inclinometer
Boian Nov 30, 2018
  1. Boian
    Boian New Member I am in bulgaria
    11
    1
    3
    Map
    Hi guys, I have a quick question if anyone has tried to mount an inclinometer/compass unit on a 90 Cruiser without one. My mod is 2001 VX 300 TDI / D4D engine. So..should i do anything else then power the unit /somehow/ if it fits the dashboard design? I found one really cheap.. :)
    Thanks!
  2. Chris
    Chris Super Moderator Supporter I am in europe
    15,909
    3,055
    113
    Garage:
    Map
    I fitted one years ago. In order to get the temperature gauge to work, you'll need the temp probe which plugs in behind the left hand headlamp IIRC. The rest is built into the unit itself and on mine, just plugged in. I think I still have the lead somewhere.
  3. Boian
    11
    1
    3
    Map
    Super cool! Did you mount it directly on the dashboard with screws? And also how did you get to power it?
    I'll make a tutorial for the forum when I complete the exercise and of course will give you credit for the info :)
  4. Chris
    15,909
    3,055
    113
    Garage:
    Map
    Yes, I mounted it on the dash. The contour of the unit sort of dictated where it sat. It came with a bracket that went inside the dash so that the screws had something to grip on but you could use a modern adhesive I guess.
  5. TALAMAN
    TALAMAN Well-Known Member I am in cyprus
    260
    108
    43
    Map
    Nice idea Boian I was thinking about doing the same!
  6. Beau
    Beau Well-Known Member I am in guyana
    1,819
    202
    63
    Map
    As chris said, the wiring is already there for it which is handy! Just plug and play, alongside getting hold of that temp sensor.
Share This Page
    Dismiss Notice
