JB Weld fixed injector pump leak
Jason Read Dec 5, 2018
  1. Jason Read
    Jason Read New Member I am in new_zealand
    15
    14
    3
    Map
    Hello, Re my post a few weeks ago about my leaking injector pump. It was leaking from the join between the main pump body and the cast iron pressure manifold.
    Only an o ring worth a few dollars but hours to take off and re fit the pump! I really could not afford to pay a garage to do it and need the truck for getting to work.
    So I removed the top pump cover and the solenoid which allowed me better access to the join where the leak was. I sprayed carb clean and wire brushed the join. Carb cleaned again. Then I spread JB Weld into the join and coved it a bit where it met the pump body on top and bottom of pump.
    It has worked! $22 nzd to fix my leak. Probably only used about the size of a couple of peas worth of epoxy. You can't even see it unless you really look. I wiped off the excess as best I could.
    Cheers and Merry Xmas everyone.
  2. frank rabbets
    frank rabbets Well-Known Member
    4,507
    910
    113
    Map
    Weld done!
    Higgy, Firewout and grantw like this.
  3. StarCruiser
    10,914
    4,261
    113
    Garage:
    Map
    :doh::eusa-snooty:
  4. StarCruiser
    10,914
    4,261
    113
    Garage:
    Map
    Another bush repair doth surface. :icon-biggrin:
    Do let us know how it holds up.
    I believe @Shayne used JB Weld to fix the hydraulic brake bleed on his Sankey trailer and AFAIK that’s still holding up well.
    Shayne likes this.
  5. Shayne
    Shayne Well-Known Member Guru
    11,048
    3,409
    113
    Map
    Yep its amazing stuff :thumbup:
  6. Jake the Peg
    Jake the Peg Member I am in scotland
    188
    124
    43
    Map
    Frank, have you been at Andy’s joke book?
  7. frank rabbets
    4,507
    910
    113
    Map
    Yes Andys joke book. It's on page 1,758,978 half way down.
    clivehorridge likes this.
Share This Page
    Dismiss Notice
