Jokes
Actual exchanges between pilots and control towers
Tower: "Delta  351, you have traffic at 10 o'clock, 6  miles!"
Delta 351: "Give  us another hint! We have digital watches!"
Tower: "TWA 2341, for noise abatement turn right 45  Degrees."
TWA 2341:  "Centre,  we are at 35,000 feet.. How much noise can we make up here?"
Tower: "Sir, have you ever heard the noise a 747 makes when it hits a 727?"
From an unknown aircraft waiting in a very long takeoff queue: "I'm f...ing bored!"
Ground Traffic Control: "Last aircraft transmitting, identify yourself immediately!"
Unknown aircraft:  "I said I was f....ing bored, not f...ing stupid!"
O'Hare  Approach Control to a 747: "United  329 heavy, your traffic is a Fokker, one o'clock,  three miles,  Eastbound."
United  329: "Approach,  I've always wanted to say this...I've got the little Fokker in sight."
A student became lost during a solo cross-country  flight.  While attempting to locate the aircraft on radar, ATC asked,  "What  was your last known  position?"
Student:  "When I was number one for takeoff."
A  DC-10 had come in a little hot and thus had an  exceedingly long roll out after touching down.
San Jose Tower Noted:  "American 751, make a hard right turn at the end of the runway, if you are able.. If you are not able, take the Guadalupe exit off Highway 101, make a right at the lights and return to the airport."
A  Pan Am 727 flight, waiting for start clearance in   Munich , overheard the following:
Lufthansa (in  German):  "Ground,  what is our start clearance  time?"
Ground (in English): "If you want an answer you must speak in English."
Lufthansa (in English): "I am a German, flying a German airplane, in Germany .  Why must I speak English?
Unknown voice from another plane (in a beautiful British accent): "Because you lost the bloody war!"
Tower:  "Eastern 702, cleared for takeoff, contact Departure on frequency 124.7"
Eastern 702: "Tower, Eastern 702 switching to Departure.  By the way, after we lifted off we saw some kind of dead animal on the far end of the runway."
Tower:  "Continental 635, cleared for takeoff behind Eastern 702, contact Departure on frequency 124.7.  Did you copy that report from Eastern  702?"
Continental 635: "Continental 635, cleared for takeoff, roger; and yes, we copied Eastern.  We've already notified our caterers."
One day the pilot of a Cherokee 180 was told by the tower to hold short of the active runway while a DC-8 landed.  The DC-8 landed, rolled out, turned around, and taxied back past the Cherokee.  Some quick-witted comedian in the DC-8 crew got on the radio and said, "What a cute little plane.  Did you make it all by yourself?"
The Cherokee pilot, not about to let the insult go by, came back with a real zinger: "I  made it out of DC-8 parts.  Another landing like yours and I'll have enough parts for another one."
The German air controllers at Frankfurt Airport are renowned as a short-tempered lot. They not only expect one to know one's gate parking location, but how to get there without any assistance from them.  So it was with some amusement that we (a Pan Am 747) listened to the following exchange between Frankfurt ground control and a British Airways 747, call sign Speedbird 206.
Speedbird  206: "   Frankfurt , Speedbird 206! Clear of active  runway."
Ground: "Speedbird 206.  Taxi to gate Alpha One-Seven."
The BA 747 pulled onto the main taxiway and slowed to a  stop.
Ground: "Speedbird, do you not know where you are going?"
Speedbird 206: "Stand by, Ground, I'm looking up our gate location now."
Ground (with quite arrogant impatience):  "Speedbird 206, have you not been to Frankfurt  before?"
Speedbird 206 (coolly) : "Yes, twice in 1944, but it was dark -- and I didn't land."
While taxiing at London 's Airport, the crew of a US Air flight departing for Ft. Lauderdale made a wrong turn and came nose to nose with a United 727.  An irate female ground controller lashed out at the US Air crew, screaming: "US Air 2771, where the hell are you going?  I told you to turn right onto Charlie taxiway!  You turned right on Delta! Stop right there.  I know it's difficult for you to tell the difference between C and D, but get it right!"
Continuing her rage to the embarrassed crew, she was now  shouting hysterically:  "God!  Now you've screwed everything up!  It'll take forever to sort this out!  You stay right there and don't move till I tell you to!  You can expect progressive taxi instructions in about half an hour, and I want you to go exactly where I tell you, when I tell you, and how I tell you!  You got that, US Air 2771?"
"Yes, ma'am," the humbled crew responded.
Naturally, the ground control communications frequency fell terribly silent after the verbal bashing of US Air 2771.  Nobody wanted to chance engaging the irate ground controller in her current state of mind.  Tension in every cockpit out around Gatwick was definitely running high.  Just then an unknown pilot broke the silence and keyed his microphone, asking:
"Wasn't  I married to you  once?"
Qantas Maintenance Reports
After every flight, pilots fill out a form called a gripe sheet, which conveys to the mechanics problems encountered with the aircraft during the flight that need repair or correction. The mechanics read and correct the problem, and then respond in writing on the lower half of the form what remedial action was taken, and the pilot reviews the gripe sheets before the next flight.
Never let it be said that ground crews and engineers lack a sense of humour. Here are some actual logged maintenance complaints and problems as submitted by Qantas pilots and the solution recorded by maintenance engineers. Qantas is the only major airline that has never had an accident.
(P = The problem logged by the pilot.) (S = The solution and action taken by the engineers.)
P: Left inside main tyre almost needs replacement.
S: Almost replaced left inside main tyre.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're there for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
S: Took hammer away from midget.
They're Back! Those wonderful Church Bulletins! Thank God for church ladies with typewriters. These sentences (with all the BLOOPERS) actually appeared in church bulletins or were announced in church services:
The Fasting & Prayer Conference includes meals.
The sermon this morning: 'Jesus Walks on the Water.' The sermon tonight: 'Searching for Jesus.'
Ladies, don't forget the rummage sale. It's a chance to get rid of those things not worth keeping around the house. Bring your husbands.
Remember in prayer the many who are sick of our community. Smile at someone who is hard to love. Say 'Hell' to someone who doesn't care much about you.
Don't let worry kill you off - let the Church help.
Miss Charlene Mason sang 'I will not pass this way again,' giving obvious pleasure to the congregation.
For those of you who have children and don't know it, we have a nursery downstairs.
Next Thursday there will be tryouts for the choir. They need all the help they can get.
Irving Benson and Jessie Carter were married on October 24 in the church. So ends a friendship that began in their school days.
A bean supper will be held on Tuesday evening in the church hall. Music will follow.
At the evening service tonight, the sermon topic will be 'What Is Hell?' Come early and listen to our choir practice.
Eight new choir robes are currently needed due to the addition of several new members and to the deterioration of some older ones.
Scouts are saving aluminum cans, bottles and other items to be recycled. Proceeds will be used to cripple children.
Please place your donation in the envelope along with the deceased person you want remembered.
The church will host an evening of fine dining, super entertainment and gracious hostility.
Potluck supper Sunday at 5:00 PM - prayer and medication to follow.
The ladies of the Church have cast off clothing of every kind. They may be seen in the basement on Friday afternoon.
This evening at 7 PM there will be a hymn singing in the park across from the Church. Bring a blanket and come prepared to sin.
Ladies Bible Study will be held Thursday morning at 10 AM. All ladies are invited to lunch in the Fellowship Hall after the B. S. Is done.
The pastor would appreciate it if the ladies of the Congregation would lend him their electric girdles for the pancake breakfast next Sunday.
Low Self Esteem Support Group will meet Thursday at 7 PM. Please use the back door.
The eighth-graders will be presenting Shakespeare's Hamlet in the Church basement Friday at 7 PM. The congregation is invited to attend this tragedy.
Weight Watchers will meet at 7 PM at the First Presbyterian Church.. Please use large double door at the side entrance.
The Associate Minister unveiled the church's new campaign slogan last Sunday: 'I Upped My Pledge - Up Yours.'
Nintendo have just brought a game out where a
14yr old boy runs around the streets of Glasgow smashing cars, stabbing people & robbing houses...........
It's called……
Wii Bastard!
Motivational posters - don't you just love them???
(Chris - that looks like Merlin :shock: )
A man in London walked into the produce section of his local Tesco's supermarket and asked to buy half a head of lettuce. The boy working in that department told him that they only sold whole heads of lettuce. The man was insistent that the boy ask the manager about the matter.
Walking into the back room, the boy said to the manager,
"Some old bastard wants to buy a half a head of lettuce."
As he finished his sentence, he turned around to find that the man was standing right behind him, so he quickly added,
"and this gentleman kindly offered to buy the other half."
The manager approved the deal and the man went on his way.
Later, the manager said to the boy,"
I was impressed with the way you got yourself out of that situation earlier, we like people who can think on their feet here, where are you from son?"
"New Zealand, sir," the boy replied.
"Why did you leave New Zealand ?" the manager asked.
The boy said, "Sir, there's nothing but prostitutes and rugby players there."
"Is that right?" replied the manager," My wife's from New Zealand !"
"Really?" replied the boy, "Who'd she play for?"
Camilla, the Duchess of Cornwall bought new shoes for her wedding.
During the big day they became increasingly tighter and tighter as the day went on.
That night, when the festivities were finally over, and they retired to their room, she flopped on the bed and said, "Charles, darling, please remove my shoes, my feet are killing me!"
Her ever-obedient Prince of Wales attacked her right shoe with vigour, but it would not budge.
"Harder!" yelled Camilla, "Harder".
Charles yelled back.
"I'm trying, darling! But it's just so bloody tight!"
"Come on! Give it all you've got!" she cried.
Finally, when it released,
Charles let out a big groan and Camilla exclaimed,
"There! Oh, God, that feels so good!"
In their bedroom next door,
the Queen said to Prince Phillip, "See! I told you with a face like that, she had to be a virgin!"
Meanwhile, as Charles tried to remove her left shoe,
he cried, "Oh, God, darling! This one's even tighter!"
At which Prince Phillip said to the Queen,
"That's my boy! He served in the Navy: "Once a Rear Admiral, always a Rear Admiral!"
THE MAILMAN'S LAST DAY
It was the mailman's last day on the job after 35 years of carrying the mail through all kinds of weather to the same neighborhood.
When he arrived at the first house on his route he was greeted by the whole family, who congratulated him and sent him on his way with a big gift certificate envelope. At the second house they presented him with a box of fine imported cigars. :cool:
At the third house handed him a selection of terrific fishing lures. :animals-fishblue:
At each of the houses along his route, he was met with congratulations, farewells, cards, and gifts of all types and values. $$$$
At the final house he was met at the door by a strikingly beautiful young blonde in a revealing negligee. :shock:
She took him by the hand, gently led him through the door, and led him up the stairs to the bedroom -- where they had a most passionate liaison
Afterwards, they went downstairs where she made him a giant breakfast: eggs, potatoes, ham, sausage, tomatoes, mushrooms and fresh-squeezed orange juice.
When he was truly satisfied she poured him a cup of steaming coffee, as she was pouring, he noticed a dollar bill sticking out from under the cup's bottom edge.
'...All this was just too wonderful for words,' he said, ......."but what's the dollar for?"
"Well," she said, "last night, I told my husband that today would be your last day ...and that we should do
Something special for you I asked him what to give you?"
He said, "....
....Screw him, ....just give him a dollar" :hand:
She then blushed and added,
"But the breakfast was my idea" :dance:
BBC News:
Prison rioters 'must be punished'
If only there was a place they could be sent to where they couldn't do this sort of thing. :think:
I've just read that 95% of Land Rovers sold in 2009 are still on the road.
The other 5% made it back to their driveways... :lol: :lol:
Glasgow Boys join Ferrari.
"The Ferrari F1 team fired their entire pit crew yesterday."
This announcement followed Ferrari's decision to take advantage of the
British government's 'Work for your Dole' scheme and employ some
Glasgow youngsters.
The decision to hire them was brought about by a recent documentary on
how unemployed youths from Castlemilk were able to remove a set of wheels
in less than 6 seconds without proper equipment, whereas Ferrari's
existing crew could only do it in 8 seconds with millions of pounds worth of
high tech equipment.
It was thought to be an excellent, bold move by the Ferrari management
team as most races are won and lost in the pits, giving Ferrari an advantage
over every other team.
However, Ferrari got more than they bargained for! At the crew's first
practice session, not only was the Glasgow pit crew able to change all
four wheels in under 6 seconds but, within 12 seconds, they had re-sprayed,
re-badged and sold the car to the Mclaren team for 8 cases of Stella, a
bag of weed and some photos of Lewis Hamilton's bird in the shower.
I've designed a new after shave and decided to call it 'World War 3', I'm going to get it produced in France.
Apparently, they are very good at bottling it. :lol: :lol:
DANGER INTERNET WARNING!
If you get an email titled "Nude photo of Ann Widdecombe", don't open it.
It contains a nude photo of Ann Widdecombe!!!!
I feel stupid. I lost the pub trivia on the last question last night.
The question was, "Where do women have the curliest hair"?
Apparently, the answer is Fiji.
______________________________
I've just been banned from a Muslim clothes shop.
I only asked for a bomber jacket.
Touchy bastards.
_________________________________________
I got sacked last night from the Salvation Army Soup Kitchen.
All I said was, "Will you people hurry up, some of us have a home to go to".
I felt sorry for the hypnotist I saw last night. He hypnotized 7 blokes then dropped the mike on his foot & said "SHIT".
What happened next will haunt me forever.
Did you hear about the fat, alcoholic transvestite - All he wanted to do was eat, drink and be Mary
Got an e-mail today from a bored local housewife, 43, who was looking for some hot action!
So I sent her my ironing. That'll keep the lazy woman busy.
I got invited to a party and was told to dress to kill. Apparently a turban, beard and a backpack
wasn't what they had in mind.
After a night of drink, drugs and wild sex Bill woke up to find himself next to a really ugly woman.
That's when he realised he had made it home safely.
Paddy says to Mick, "Christmas is on Friday this year". Mick said, "Let's hope it's not the 13th then."
My mate just hired an Eastern European cleaner, took her 5 hours to hoover the house. Turns out she was a Slovak
I've been charged with murder for killing a man with sandpaper. To be honest I only intended to rough him up a bit.
After years of research, scientists have discovered what makes women happy. Nothing.
A lad comes home from school and excitedly tells his dad that he had a part in the school play and he was playing
a man who had been married for 25 years. The dad says, "Never mind son, maybe next year you'll get a speaking part."
Just had my water bill of £175 drop on my mat. That's a lot. Oxfam can supply a whole African village for
just £2 a month: time to change supplier I think.
2 women called at my door and asked what bread I ate, when I said white they gave me a lecture on the
benefits of brown bread for 30 minutes.. I think they were Hovis Witnesses
Nick.
I've just come out of the shop with a meat and potato pie, large chips, mushy peas & a jumbo sausage.
A poor homeless man sat there and said 'I've not eaten for two days'
I told him 'I wish I had your flamin’ will power'
Top tip; if you're camping in the summer and the attractive girl in the next tent tells you that because it's so hot she will be sleeping with her flaps open, it's not necessarily an invitation to casual sex.
Wish me luck; I appear in court next Monday.
I got fired on my first day as a male masseuse today.
Apparently the instruction 'finish off on her face' didn't mean what I thought it did.
I took my Biology exam last Friday. I was asked to name two things commonly found in cells. Apparently "Blacks" and "Paki's" were not the correct answers.
A fat girl served me food in McDonald's at lunch time. She said 'sorry about the wait.'
I said 'don't worry fatty, you're bound to lose it eventually '
I walked past an abo kid sitting at a Bus Stop as I came out of the Bank. He looked at me and said 'Any Change'
I said 'Nope! You’re still Black'
Snow in the forecast! The TV weather gal said she was expecting 8 inches tonight.
I thought to myself “fat chance with a face like that!”
An Irish boy stands crying at the side of the road.
A man asks ‘What is wrong’??
The boy says ‘Me ma is dead’
‘Oh bejaysus’ the man says ‘Do you want me to call Father O’Riley for you’??
The boy replies ‘No tanks mister, Sex is the last ting on my moind at the moment’.
I have a new pick up line that works every time. It doesn't matter how gorgeous or out of my league a woman might be, this line is a winner & I always end up in bed with them.
Here's how it goes 'Excuse me love, could I ask your opinion? Does this damp cloth smell like chloroform to you?'
Years ago it was suggested that an apple a day kept the doctor away. But since all the doctors are now Muslim, I've found that a bacon sandwich works best!
Japanese scientists have now created a camera with such an immense shutter speed that it is now possible to take a photograph of a woman with her mouth closed.
I hate all this terrorist business. I used to love the days when you could look at an unattended bag on a train or bus and think to yourself ‘I’m having that’
Man in a hot air balloon is lost over Ireland. He looks down and sees a farmer in the fields and shouts to him ‘Where am I’??
The Irish farmer looks back up and shouts back ‘Ya canna kid me ya flash bastard. You’re in that friggin basket’.
That is a good one as one of my mates is ex German Navy and now works for coastguard!
This has to be my favourite though... Unbelievably (or totally believably) this actually happened in 1995 between USS Montana and an Irish lighthouse.
[youtube:2ztxebuz]j5onkl2EHV4[/youtube:2ztxebuz]
That one cracks me up every time. :lol:
Paddy was waiting at the bus stop with his mate when a lorry went by loaded up with rolls of turf. Paddy said, 'I gonna do that when I win lottery'
'What's dat, says his mate.
'Send me lawn away to be cut'.
