Saffe
- Jan 5, 2015
Saffe just thought wastegate creep could cause your problems though it would have to be quite severe , have a look here about fitting a boost controller which would cure it if that were the case .
http://www.landcruiserclub.net/foru...nic-Diesel-Tuning-Devices?p=458738#post458738
Hello Shayne (and the rest of you)
To close this thread I eventually (a half year ago) found the problem... It was the valve of the waste gate that didn’t closed completely. When I dismounted the bracket that holds the valve rod (and by this action it closed the waste gate valve) I heard the turbo spinning up when engine runned at
idle.
Thanks again for all the help
