tony rodaway
- Aug 28, 2016
Hello members i have a strange problem with my lc90 on first start up.
I left for work yesterday at 5.45 and car was all good but came out for my break at 10.45 and went to start it up to go somewere but the car was dead as just one click as battery seemed lifeless.
I got a jumpstart but did,nt seem to do any good as just got 3 to 4 clicks with little power it was gaining.
I changed my main battery for my axuillary one and went to jump start and straight away you could tell it was drawing power from the jump start so i tried to start and bingo first time.
Seems i have a dead battery so i drove for around 1.5miles with auxillary battery on and stopped and started again and car was dead again.
I got another jump start and went to get a new battery £91 and came home and put it on and started it up and bingo first time start so problem solved but no as i turnrd the engine off and started it up again one click with new battery on and this was not a battery fault even alternator would not kill a new battery that quick.
In the mean while my auxillary battery was on charge and since it was not a battery fault i removed the new one and replaced my original one back on and started the car and it started first time so deffo not a battery fault.
The car has started every time since BUT now startes like the battery is dieing on first start up or if i leave it for a few hours at least.
One first start up it sounds like it does not have the power to start and seems more white smoke than normal but just fires and then all is normal as drives perfect.
If i drive and stop and start up again it will fire up no problem like power is restored but to be honest i dont think its taking any power out the battery just there is some thing else that seems the problem.
Wth my symtoms i thought i may have a short somewere or faulty glow plug but to get a new battery and not start that is not a power fault but may be a sensor or machanical fault but what can it be causeing this problem.
My dash has no warning lights from battery or alternator and starts so not starter fault either.
ANY IDEAS AND HAS ANY ONE HAD THIS PROBLEM AS I NEED MY Car FOR WORK AS IT STANDS NOT SURE IF IT WILL START WHEN I GET IN IT.
