Progress!
Most of the frame is wirebrushed and primed, also got the motor into the frame loosely where it will be, It will have to go back like 5-6cm in the pics though, crank belt disc is almost hitting the front chassis crossmember now
2017-08-05 14.06.26 by
Vc1r, on Flickr
2017-08-05 14.06.40 by
Vc1r, on Flickr
2017-08-05 14.06.49 by
Vc1r, on Flickr
2017-08-05 14.07.03 by
Vc1r, on Flickr
2017-08-05 14.14.02 by
Vc1r, on Flickr
2017-08-05 14.14.04 by
Vc1r, on Flickr
Will probably remove the chassis mounts and make new ones further back, also gonna have to fab up some new for the motor, then im probaby gonna join the two together using these bushes
http://swedenfabrication.se/index.php?route=product/product&path=18&product_id=182
The oilpan has the deep part forward on these engines, which puts it directly above the front axle, looks like it'll work, but gonna lenghten the bumpstops, and also gonna move the axle forward about 10cm..
Thinking 3-link would be awesome for the front, either that or use the rear stock trailing arms and put them upsidedown on the axle, thus getting them in a more stock height giving me more travel downwards
Im thinking i'll be doing something like 270cm-ish for the wheelbase, stock is about 230cm if i remember correctly, so rear axle will also be moved, and for the rear im thinking triangulated 4-link to get rid of the panhard rod..
