LC 200 Sahara 2017
RGraham
australia
The GPS and Bluetooth are unavailable if you go over 10kp/h. Is there anyway to override this system or shut it down so passengers can use it while the car is in motion?
Sigh. We no longer get the 200 series in the UK, and there aren't many owners on here. I suspect your answer lies either on an Oz or South African site. Or maybe even ih8mud
I Have heard of a way in the 150, would be similar to 200 I would think
The 120's LC5 have the same issue and I would like to know workaround. It sticks that the passenger can't work the nav system on the move, other than set destination to home.
There is a way but it is very involved from memory. I haven't done it.
Hi RGraham
I have heard of a way by placing a rocker switch on the wire that senses movement of the vehicle. This is done before the wire enters the multimedia system, which will then "trick" the nav system to thinking you are stopped. this worked well on my previous vehicle Pajero, but I haven't yet had it done on my few months old VX. Go and look on UTube, as I saw something there that was interrupting the white wire feeding the nav system.
Good luck.
