friday night i removed the fuel tank.
it came out quite easily. couldnt believe how big it is, i knew it was a 90litre tank, but it really is huge!
so yesterday work could finally start on the bodywork.
my 2 mates are helping me do this, as they know what there doing....................i hope.
so to start with they cut all the brackets off that held the fibre glass arches on. they then welded steel over all the holes on the off side front arch.
i then removed all the timber panelling from the back of my truck, followed by the rear lights and all the wiring.
they removed some of the paint and underseal to get down to bear metal.
blowtorch and old wood chisel worked best for this.
they marked where the new panel would come to, and then cut a section of rusty panel out.
no turning back now.
bit more for the scrap pile.
they then punched a load of holes in the new panel ready for spot welding.
before clamping and welding it in place.
the back of the panel needed a slight bit of fettling to make it fit perfectly.
one panel on.
just the gap between the new panel and body, inside the arch to fill now.
so they bent some steel to suite.
between making the lads cups of coffee, and getting in the way taking bloody photos.
i removed the rear trailing arms and panhard rod from the rear axle.
pics showing how badly elongated and enlarged the rear shock mount holes now are.
i then made some lunch. sausage and egg sandwiches.
rot all cut out and new metal going in.
i then put the arms, panhard rod and axle on a pallet and took them down to the pressure washer and gave them a good blast of hot water, to try and remove as much oil, rust and shit as possible, ready for painting.
bushes look knackered, so will need replacing.
im actually thinking of making new arms front and back and using rose joints on the end that attaches to the chassis, as that should give me better articulation, as im sure the bushes must currently bind up when its articulating.
back to the bodywork and the lads were busy welding away.
looking good.
i then gave it a quick coat of spray to stop it rusting, until it gets painted which will probably be a few weeks.
axle on stands, ready for my angle grinder with wire brush fitted to remove all the rust.
so that was yesterday.
the lads will be back next saturday hopefully to weld the other side.
then theres a shed load of work to do with filler and paint to get it looking perfect.
