LJ70 New owner
Si LJ70
I am in great_britain
Jan 5, 2021
18
8
3
Reading Berkshire
Hi Everyone,
The LJ70 had been sorn for a few years so needed an MOT.
Took it to the MOT garage today. I am expecting a long read when it's finished! One thing I noticed driving it was the steering had quite a lot of play. I am assuming it's the steering box. Do you guys know a good place to get one? Also the engine won't shut off unless the lights are off its that normal?
Cheers,
Simon
iwan_t24
I am in wales
Mar 28, 2011
1,527
816
113
Mid Wales
There's an adjuster on the steering box.. on the top theres a 19mm nut and the threaded part is a flat screwdriver slot.
Just don't do it up too tight, adjust it so there's a minimal amount of play on the steering wheel. Then cycle the steering wheel to check there aren't any tight spots.
It'll be as good as new!
Juddian
Jun 17, 2019
156
202
43
Kettering, Northamptonshire
Can't recall anything complicated on my 70 series such as an inhibitor to prevent the engine being stopped with the lights still on, wondering if there might have been an ignition or stop solenoid wiring fault sometime in its life and someone plugged in a feed that got it going.
Check the oil level in the box if and when you adjust the free play up as described above.
  • Like
Reactions: Tractionman
Si LJ70
Jan 5, 2021
18
8
3
Reading Berkshire
Thanks iwan-t24! Is that adjustment possible without a ramp?
About the engine not turning off with lights on. The previous owner has told me it was rewired recently so probably a connection mistake.
Another thing I noticed was very slow windscreen wipers. I am assuming a new motor is required.
Cheers!
iwan_t24
I am in wales
Mar 28, 2011
1,527
816
113
Mid Wales
With the steering box adjustment... to put the axle on axle stands and easier to take just the driverside wheel off for better access..
Si LJ70
Jan 5, 2021
18
8
3
Reading Berkshire
It failed the MOT. But only on a wheel front wheel bearing, windscreen washer and horn so could have been a lot worse so worth the gamble.
Will still adjust the steering box as it sounds quite easy.
Another question.: The previous owner has replaced the turbo with a supercharger. It runs ok but sounds like it is over fuelled (pinking). Is it possible to adjust the fuel air mixture manually? Or can anyone recommend a engine tuner near Berkshire?
qbartx
Nov 21, 2018
56
25
18
It won't shut off as it feeds shut off selenoid on the pump from headlight + . Used to be a trick back in the day to not forget the lights. Do not assume that they have found all the plays in the suspension when doing an mot. First thing to do, get someone to keep turning steering wheel left-right when you lay under the car. Look especially at panhard bushes, there shouldn't be any play there. Go for tracking first as they feel"loose" when it's out.
Wiper motor will be ok, mechanism will be seized on the spindles only way is to take it out, take circlips off, slide them out of mounts and clean/grease. If you look under wiper arm you will see if they are on an angle and the casing is worn. If yes just replace mechanism.
Did he put a boost gauge there so you would see what pressure you're running? Is the wastegate on that charger plumbed in properly?
Si LJ70
Jan 5, 2021
18
8
3
Reading Berkshire
Thanks qbartx I will investigate the wiper spindles.
About the engine stuff I literally only picked up the LJ70 up today and drove it straight to the MOT test garage. I only have a basic understanding of turbo and superchargers/ waste gates hence why I need help from a specialist. In the meantime I am going to read up on subject... Gives me something to do during lock-down.
qbartx
Nov 21, 2018
56
25
18
Post a few close up photos around the charger. How much it's blowing mainly depends from size of the pulleys.
Si LJ70
Jan 5, 2021
18
8
3
Reading Berkshire
I just checked in the manual and there isn't one .
The horn doesn't work. Checked the fuse, horn connections, I guess next is the steering wheel switch. Unless there is a known fault?
Tractionman
I am in england
Oct 11, 2013
983
736
93
That power box you have found I is not the main fuse/relay box. That IIRC has large capacity for winch etc.
The main box is behind a pull off panel by drivers right foot/throttle pedal, take a look in there. All the information on what's in there is marked on the reverse of the pull off panel.
  • Like
Reactions: iwan_t24
qbartx
Nov 21, 2018
56
25
18
Can't really see anything on these photos that's why i said close up, especially bypass area( vac actuator on outside of charger).
Did you actually put power to the horns see if they work? Never had the relay go but it must be one of the ones under steering column. Unbolt the vent and have a look, it will probably be one of the funny "can" type relays
AdBlock Detected
