Iwan
- Mar 28, 2011
After having a near miss on the lanes yesterday, very lucky that there was space to slide past the obstacle in my path mk7 golf!!
First thing this morning I had to take a look.
Shoes and cylinders good but very easy to remove the drum.. As soon as I got the drum off I was looking into adjusting the sprocket and saw that through the thin slit in the backing plate the hand brake auto adjuster is right in the way and when you try to use a screw driver to adjust the auto adjust lever and release.. it turns the sprocket back to where it was!! Not adjusting it at all!!
So at 12 o clock on the hub there's a hole but behind it there's a metal plate blocking the access to the adjustment sprocket. So drilled it out to 13mm and the sprocket is nicely in sight now.
At first drilled the drum out to 13mm but it didn't line up so drilled to 16mm through one of the smaller outer holes.
Good access to the sprocket from the front now (just like an 80 lol), good for adjusting up but the hand brake adjuster once again stops you from un adjusting I found..
I used a hooked pick through the thin slit to pull the handbrake adjuster away from the sprocket to allow you to un adjust the sprocket... also when you see the handbrake dogbone sat on its stop rhs then it's set pretty good!
Hooked on and pulled away to allow un adjustment when the drum is back on.
Have a 3 click hand brake which is great but.... its still locking up on the front. So decided to take a look at the LSPV and it's seized in the unloaded position and the rear braking pressure is going back down to the front as far as I can tell after removing the connection to the rear axle.
It has 90 series front calipers with vented front disks and an 80 series dual brake booster and master cylinder with 70 rear drum setup! A bit of a mix I know lol! But has previously worked and passed 2 mots with this combination.
Ideally I want shot of the LSPV and buy an adjustable unit that will allow me to set the rear flow. If anyone could point me in the direction of the solution that'll be great.. i've read today that it's a 65% front to 35% rear bias?
Be a shame to wipe the truck out if used without repairing! TIA
