Trevor
- Jul 25, 2010
Having recently bent my steering bars, I sourced a replacement set but needed to transfer the track rod ends off my old bars and have them put onto the replacement ones. The track rod ends were marked before removal and refitted back to those marks on the new bars so are in the same position.
I have now fitted them and have found that turning from centre position, it takes 1.5 turns to left lock and 1.25 turns to right lock. It is very obvious that the wheels are turned out much more on left lock than right lock. The steering arm connected to the steering box does move through the full range if I disconnect the ball joint to the steering bar.
I'm thinking that something else is bent on the nearside which is stopping the full movement, the rear steering arm behind the front axle is straight and I suspect it's the nearside steering arm (stamped L4) which connects to the top of the nearside hub. Also the front of the arm which connects to the ball joint looks very very close to the backing plate of the front disc.
Photos are below and wondering if some kind soul could compare against their working LJ70, as you look at the photos, the top right front nut out of the 4 appears to be bent over a bit but I'm not sure if that's normal.
Any advice humbly accepted and p**s taking will be taken like a man.
