Hi Folks
I would appreciate some advice on a problem I have with my LJ78 Japanese import "H" reg. Went into my garage the other day after several weeks and found a small pool of transmission fluid under the near side front wheel. I'm guessing that the gasket around the ball joint on the end of the axle has been breached. Is this a fair diagnosis? I took the wheel off and the fluid seems to be running down the back of the plate behind the wheel and is not touching the disc. Secondly, how difficult/expensive is this to fix? Thirdly, is there a "work-round" i.e. could I fill the ball joint with the type of thick grease Land Rover supply for some of their models? And lastly, someone has mentioned to me a gasket repair product you just poor into the transmission fluid which seals any gaps - has anyone else heard of this and tried it out?
Many thanks for any words of wisdom.
Keith
Keith
