G'Day,Sharing info for those who may need to find/access/replace the reverse (back-up) light switch in HZJ105 (01/1998 to 02/2008) View attachment 164033
Not odd at all, if you were looking for your reversing light switch on a 105, useful info every day’s a school dayOdd thing for a 1st post, just saying
...I always wonder if the h151f was fitted from factory with the 105?
Well done Holmes, great detective work, the question is, are you going to find and fit a R151F box fitted as OEM to the HZJ105 variant?UPDATE:
Information from Toyota indicates that the H151F gearbox was only installed as OEM in FJZ100 (inline 6 petrol), HDJ100 (inline 6 turbo diesel) and UZJ100 (V8 petrol) variants as it was a stronger box capable of handling more HP and torque than the R151F box installed in HZJ105 (inline 6 diesel) variant. Both gearboxes were reported to have the same gear rations and to be interchangeable but the dif ratios would be different between variants.
This leads me to conclude that the gearbox in my HJZ105 must have been exchanged by the truck's original farmer owner during his ownership some 8 years before I bought it from him.
My original post then refers exclusively to the H151F gearbox and not to the R151F box fitted as OEM to
HZJ105 variant.
No, I am happy with the gearbox I have, especially after I located and replaced its unreliable back-up light switch .Well done Holmes, great detective work, the question is, are you going to find and fit a R151F box fitted as OEM to the HZJ105 variant?
Good Luck.
Well doneNo, I am happy with the gearbox I have, especially after I located and replaced the old unreliable back-up light switch .
UPDATE:
HZJ105 variant.
Good Luck.
No, most of what I say to Watson is JibberJabber.Thanks for the answer to my question, I've always wondered about which 105 has the better transmission, from the post before it gave the clue of the fact that your truck had had a transmission upgrade to the h151f and a very popular upgrade if you are towing. Even with the h51f you should keep in 4th gear when you're towing heavy weight... no need for 5th as it's a little weaker 4th is direct drive and strong!
Holmes! Holmes is suggesting to down grade to a r151f trans from a h151f upgrade! Do you know what you are saying?
