- Mar 1, 2010
What's the longest lasting radiator these days please ? My new Toyota one lasted less than a year !! Thanks in advance.
I've just had a look at the fins and bottom/top plates with magnifying binoculars and torch and can't find any damage to the fins etc. Not even marked paint. However I took the end plates off and found that the side tags have only been bent over to 45 degrees, not 90 degrees like the rest. It looks like there is a leak here on drivers side as the bolt threads are corroded. This would explain the dripping on this side and also, when I thought I was using water, I could not see any coolant on the bottom plate. Is the gasket rubber TP ? I shall confirm with the air line tomorrow and if this is where the leak is tighten up the tags fully.
You're a star TP !! This reads 0.420". This is outside the range quoted in the manual of 0.362-0.378
