Steveindar
- Nov 17, 2014
Hi All,
My 1HZ has been loosing up to 1 liter of coolant per trip/day. I noticed some staining on the rad from the plastic header so pulled the rad and stripped and cleaned the header gasket etc. All together and no more leaks there, but...engine is still loosing coolant. There are no traces of it leaking from pipes or welsh plugs or such. No oil in water or water in oil. Where is it going? Where/How to look for the problem? Could it be head gasket leaking direct through to piston under pressure?
Steve
Steve
