- Mar 1, 2010
I bought this box at a local auction. Made by Dreyfous, Mayfair in 1875. It's solid mahogany with silk lining and leather covered. Gold plated fittings. Described as a document box/jewelry box. Just larger than A4. The handles are fixed on the box and control the combination lock. There are 20 clicks to each handle so 8000 combos available. The lid was open but the lock closed with unknown combo. I took the front lining out, removed the lock and revealed the combo. Then recnditioned everything and put it all back together. Combo was 1,2,3. What amazed me after some study was if the lock is open you can alter the combination by pressing in the little brass skewer stored in the side rhs frame. This resets the lock and you can turn the handles to the desired number of clicks. Removing the skewer resets the lock to the new combo. Then you can close the lid and turn the handles to lock. Best to double count first to make sure you remember correctly and the lock opens as when locked the box must be destroyed to get in without the combo.
Handles turn indefinitely clockwise but come up against a stop anti clockwise to give you a known place to count the clicks from.
I expect a lot of boxes must have been scrapped due to combos being lost over 150 years
