Graham
Mastervolt Mass Sine Inverter.
12volt DC to 2000 Watts at 230 volts AC
Pure Sine Wave Power Inverter
12vDC - 230vAC
The New RRP of these is £1750... A TOP QUALITY PURE SINE INVERTER SUITABLE FOR ALL TYPES OF APPLIANCES,
An on board or in your expedition 4x4, an AC installation offers you a wealth of benefits by making possible the on board use of many domestic appliances, From oven to microwave, and your hand power tools.
A Mass Sine inverter allows you to easily transform the voltage of your 12V battery to 230V/50Hz, so you can enjoy all the comforts of home wherever you choose to go.
And you save on the costs associated with adapting equipment to work on 12 volt low voltage.
This superb Mass Sine inverter converts battery power to 230V/50Hz with minimum heat generation.
From regular TVs to flat screens, LCD and Plasma, from electric kettles to icemakers, from drinks cooler to coffee machine, even the all important her hair drier and heated rollers !
Everything functions perfectly. There is an automatic stand-by or scan mode for no-consumption periods. You always will have AC power, even without outside electric hook-up, such as at caravan sites, or canal boat moorings.
The inverter can easily give you all you need in relation to running 230 Volt AC gadgets.
AC power on board or in your expedition 4x4 gives you a home from home!
[url]www.mastervolt.com[/URL]
I'm reluctantly selling this inverter due to finishing my expeditions for the foreseeable future.
This inverter has served me well for the last two years, running mostly a fridge and a freezer, and of course the vacuum cleaner, kettle, toaster, and the iron, for them smart days out, and of course, all the charges.
Here's your chance to grab a bargain.
Here are the specs for you:
Output voltage (± 5%) 230 V – 50 Hz (± 0.01 Hz)
Output waveform true sine
Nom. battery voltage 12 V
P30 power at 40 °C, cos phi 1 2000 W
Cont. power at 40 °C, cos phi 1 1800 W
Peak load 4000 W
AC connection internal
Efficiency 92 %
Dimensions, height = 420mm, width = 318mm, depth = 136mm
16.5 x 12.5 x 5.4 inches
Weight 14.6 kg
SAFETY: I have the output from the inverter into a protected RCD tripping double 13amp socket.
You can be sure that should you plug a defective appliance into the output sockets, there is immediate disconnection, and the maximum leakage to earth is just 30 milli amps.
My safety and your safety are never in any danger.
£350.00
On Ebay next week,
Gra
