Rob Cowell
- Nov 15, 2011
Spotted a finger sized hole in a sill over the summer. MOT coming up I thought I should throw a patch at it today. Of course having cleaned it up the hole was bigger than it first looked. This is looking towards the rear.
Chopped out the weak stuff. Looks new in there apart from the rotten bit.
No pics of the patch. Not my best work but there's a seam all round it! Worth noting though this seems to have been caused by a missing grommet. There's an 18mm hole in the sill above this point. Just in front of the rear floor pan "crossmember". Worth checking theres a grommet in yours to save yourself this trouble. Mine is plugged with a grease impregnated piece of cloth until I can source a replacement. Gave the sill a good squirt of Dinitrol cavity wax while I could get at it.
Thought I'd jetwash underneath while I had the extension lead out and spotted the top control arm on the other side had ripped off its mounting! Had this happen on the other side 6 months ago. Milner poly bush very worn. It's done 60K miles since I fitted them. Will replace with a genuine arm and bushes.
Finally, as I'll likely get a new arm from Amayama or Partsouq, I need a new bracket that holds what I think are ABS wires to the cross member the top arm mounts to. Had a look on Toyodiy and can't see ABS cables. Anyone spotted them? This is the bracket.
