Can't help liking them, it's almost a shame to put them under the truck
All bled up, need to drive it to bed the pads in.
Had the engine running while laid underneath and I've got a cracked cat converter that'll be from when I bent the exhaust then! Slider needs to come off, the slider with a dent under the cats so has done it's job at least.
I thought that's how they were? time for a brake overhaul I think...Shame about the cat crack (?)
You'll feel all the benefit when the pads have bedded Gary.
Mine are not so pretty, but a while back I had 3 pots refurbished, the 4th was the only one working properly....
But what a difference! I can lock-up easy now, whereas before I'd be standing on the pedal with my head against the roof lining for leverage
She deserves it. You know the saying, happy cruiser happy life.While I've got some free time, I appear to be missing a few parts
Few bits of corrosion to sort out on the drivers side wing before it sets in.
The passenger side is getting replaced, behind the arch extension is a bit worse for wear towards the back and it's had a knock need to re shape the front corner of the inner arch slightly too!! Arch extension has a crack to fix too, new side lamp to fit aswell
Wing is currently with my mate who did the tailgate, the other one will be going for a bit of paint too.
Need to order some new pin stripes to match the rest.
It turns 20 years old on 21st August!! Time for a Little bit of tlc for the old girl.
Well, if it makes you feel any better both of my wings are shot, and the inners.
at some point ill be making a expensive trip to see mr Ts extended family..
