Tags:
  1. StarCruiser
    10,289
    3,920
    113
    Garage:
    Map
    I came to realise over the weekend that I'm well and truly on the slippery slope now so decided it's time for a general thread on my truck. I'll be adding stuff as I go along (to both the truck and the thread) :).
    It's an HDJ 81 12v 1HD-T Auto. Around 165000 on the clock but the first 90,000 of that was in km. So around 135,000 miles.
    hopeless wanderer likes this.
  2. StarCruiser
    10,289
    3,920
    113
    Garage:
    Map
    Had a little look yesterday at places to fit connectors for external equipment I intend fitting later. I've always looked at the inside reveal of the tailgate as a good possible spot to mount stuff discretely without drilling holes in the roof.
    I found two positions to fit 50A Anderson connectors without fouling anything.
    There should be plenty of room to fit wires through and around when the tailgate closes within reason. One of these will be for power to the roof tent, the other will be a different colour for connecting a solar panel if and when I get one.
    Future plans are for some radio coax cables to run through if I can find suitable angled connectors and possibly lighting.
  3. StarCruiser
    10,289
    3,920
    113
    Garage:
    Map
    First camping trip of the season. A weekend away at Sixpenny Handley for a spot of laning and driving across Salisbury Plain.
    For a while now, I've been looking at creating some way of easily getting the roof tent up onto the roof and then once it's up there and deployed, to be able to detach it and drive out from under it.
  4. chapel gate
    chapel gate Well-Known Member Supporter Promoted Company I am in england
    2,997
    1,729
    113
    Map
    Mines up in the rafters attached to a cheap ebay electric hoist, drive under it, lower the hoist, fix and drive off to the next far flung corner of the planet... etc.
  5. StarCruiser
    10,289
    3,920
    113
    Garage:
    Map
    Well today all the bits were ready and while out camping for the weekend I put it all together and tried it out. IMG_1172.JPG
    It consists of a track on the roof rack, a corresponding track on the underside of the tent, plus four attachment tubes to take leg extensions to which modified props were attached.
    Result:-
    Complete failure. Too much weight over the side of the truck to be able to jack it successfully…and safely. Then the sliding track stuck while reattaching the tent.
    So, no, this idea is going in the bin!
  6. Lorin
    Lorin Well-Known Member
    1,152
    193
    63
    Map
    Sixpenny Handley is just up the road from me. Fantastic area. Where abouts are you camping?
  7. StarCruiser
    10,289
    3,920
    113
    Garage:
    Map
    We are in Church Farm Lorin.
    Fancy joining us?
  8. clivehorridge
    13,981
    3,912
    113
    Garage:
    Map
    That's disappointing Rich, is it a design fault or a manufacturing defect?
    I suspect the design, those tents are heavy and I'd imagine the props would have to be very rigid to stop twisting and the whole thing becoming unstable.
    Is there a Plan B to hand?
  9. StarCruiser
    10,289
    3,920
    113
    Garage:
    Map
    Seriously flawed design I'm afraid Clive.
    Plan B, hmm, no, not yet anyway. And with two failed projects under my belt this year I'm fast realising it's going to be cheaper and easier to reconsider the whole roof tent idea.
    Neither Lynn nor I want to sleep in a tent on the ground so that's out. We would like to be able to pitch up at a campsite and have some transport we can easily jump in and pop down the road for 5 minutes if we need to.
    Love the Howling Moon but…
    clivehorridge likes this.
  10. Shayne
    Shayne Well-Known Member Guru
    10,834
    3,167
    113
    Map
    What props did you use Rich ? i gave up searching for some about 4ft high (adjustment either way) with a weight rating better than ok...ish .
  11. chapel gate
    2,997
    1,729
    113
    Map
    Ah, a "in the field" mounting de- mounting system.
    Electric mountain bikes have come of age now..
    Heaumey and clivehorridge like this.
  12. StarCruiser
    10,289
    3,920
    113
    Garage:
    Map
    Good thought CG, but Lynn's just not safe on a bike…
  13. StarCruiser
    10,289
    3,920
    113
    Garage:
    Map
    They were Faithful ones like this Shayne.
    https://www.ebay.co.uk/itm/222029288455
    Shayne likes this.
  14. Lorin
    1,152
    193
    63
    Map
    Would've been great to join you. We were all set to camp this weekend too - it was to be our first trial of a new tent and camping with the little one. Unfortunately she is running a temperature so camping is off.
    I was only just down the road this afternoon in Cranborne walking the dog. If I'd have known I'd have popped up to say hi. I hope you have a good time of it.
  15. StarCruiser
    10,289
    3,920
    113
    Garage:
    Map
    Thanks Lorin, I'll try and remember the next time.
    Weather's looking a bit dodgy so it looks like we will pack up in the morning and tour round Salisbury Plain with the tent on top.
    Hope the little one is feeling better soon.
    You could always join us round Salisbury Plain tomorrow. @stumog is a possible as is Chris @Lund.
  16. chapel gate
    2,997
    1,729
    113
    Map
    Have you got a swing out rear wheel?
  17. StarCruiser
    10,289
    3,920
    113
    Garage:
    Map
    No, it would get in the way too much for my daily use.
  18. chapel gate
    2,997
    1,729
    113
    Map
    I thought being an import it might.
    there would be a ready made fixing and pivot point to make a swing out boom with a simple hand operated hoist.
  19. Towpack
    Towpack Well-Known Member Supporter I am in england
    3,036
    800
    113
    Garage:
    Map
    How about making a collapsible frame with 3-4ft legs to pitch the tent on (off) the ground leaving the truck free to move as/when required. There was a guy on the Scottish campsite we stay on a couple of years ago who had done just this. Both he and his Missus didn't want to sleep on the ground so he fabbed up a frame with 3 ft legs from Ali scaffolding poles to mount the rooftop tent on (no idea what make the tent was). Just a thought.
    StarCruiser likes this.
  20. StarCruiser
    10,289
    3,920
    113
    Garage:
    Map
    I expect the 4 I have will be for sale shortly. I think they would cut down quite easily to suit around 4 foot high.
Share This Page
    Dismiss Notice
