Steve H
- May 22, 2010
Hi Guys. When checking my truck today I noticed that both UJ's in the front prop are worn. Have filled them with grease at the moment to keep using the truck for a couple of days. What make of joints would you or have you used. I fitted a Roughtrax one in the rear last year. Milner use TOYO joints with the grease nipple on one end rather than in the middle, easier to get to. Will be looking to do these soon. Also am I right in thinking I can take off the front prop and use the truck with the centre diff locked without causing any damage? If I can the wife can use it while I replace the joints in the shed at my leisure.
Thanks in advance
Thanks in advance
