Need some help to locate a leaking from the front-end of the upper engine oil pan
zhloea
united_states
Hi, I recently purchased a 2004 land cruiser (lc100), it has 174k, the timing belt changed at 90k, I will let someone do the timing belt in this month. I did an engine oil change last week, during this I found some leaking oil around the front-end of the lower oil pan, I mean the far end from the engine oil drain plug, the area around the oil drain plug end is nice and clean. Seems it comes from the front end of the upper oil pan, I also think it would be very possible to be a front crank seal, timing cover, or cam seals too, the picture below, could you give me some advice? thank you in advance!
