Less than 2 weeks away from our Pyrenees trip and still loads to do - and now the 80 has a thrust bearing issue - terrible timing!!. Noise when the clutch is not engaged which goes away when it is engaged.
Do you suggest I change the clutch as well?
I don't think ill be able to do it myself (would try if I had time) - can anybody recommend a good mechanic in the Livingston/Edinburgh area who will not charge an arm and a leg?
Also - where would you recommend I get the parts - or do I go with Toyota only?
Tobie
Tobie
