Matey Matev
- Dec 28, 2018
Hi, you could have a look on Toyodiy and put other model numbers from the vehicles that have the parts in so you can get the bits and fit them. Amayama.com may also be a source of a parts diagram, and one of the best sources for the bits.View attachment 152762 Hello from Bulgaria! I own an 1998 Land Cruiser 105 4.2 diesel non turbo. I have a question about the back doors. They don’t have wipers and no motors, all the other 105 that I have seen do. Is there any other 105 that don’t have it, or mine had and someone took it out before I bought it, no holes for wipers also. I would like to put motors and wipers if possible. Any help and advice will be much appreciate it.. Thank you..
Thank you. I will look into it..Hi, you could have a look on Toyodiy and put other model numbers from the vehicles that have the parts in so you can get the bits and fit them. Amayama.com may also be a source of a parts diagram, and one of the best sources for the bits.
I will look in to it tomorrow, there are two 80 that are sold for parts near me,hope they have everything I need to make the swap.They are separate mechs (somewhat stating the obvious) but somehow they’re electronically synced. I don’t know how, but I’m guessing mine are the same set-up on my 80 with ‘ambulance’ doors like yours.
The switch is on the wiper stalk (RHS) it has a 5 position rotating end to the stalk, off-water jet-dwell-on constant-and-on with water jet.
So for the full kit you need the 2 wiper mechs, the water jets, hosing to the front screen wash bottle and a different bottle with the extra pump, that’s if you go OEM with everything.
It will cost a fortune IMO, I’d suggest trying to find a donor 80 with ambulance doors, and hope they’ll fit.
On that from Clive. Might take a bit to make them fit but then again might not. As said, a small fortune New I’m sure.
I am one of this people that want everything to be in place with their car.I am looking into a rack also. The problem here in Bulgaria is that everything for this rig is so hard to find, everything gets shipped from Australia and is quite expensive( talking about accessories),everything else from Toyota and is a big wait..One way of looking at it is that you are lucky: Rear wipers just scratch the glass, and it's impossible to keep the rear windows clean without lotsa water. Also, when you actually use your cruiser's cargo space, or carry passengers, you can't see much anyhow. The idea is: just learn to use the side mirrors, and be happy. Install a reversing camera if you need to reverse with children around, it's cheaper than wipers anyhow.
Some forum members reported that the first thing to do with any new (for them) cruiser, is to remove the rear view mirror and rear wipers, as it's just in the way.
Nice cruiser - Looks like you have to get a rack - with those nice steps.
