Archie
- Dec 28, 2015
Hi guys,
Hope someone can give me some tips how and what to use/select to get up a slippery hill. I have lc5 5 gear auto. For example, yesterday i tried getting up a frozeb hill, first i did it without locking the dif, and it was fine. Once i locked the diff and put the gear in L it went hald way and then started to just spin on the spot. Could not go any further. One guy that used to have lc told me to always lock the dif then change from High to low, and also change the gear to L, but once i do that it just spins on the spot and bearly goes any wurther. Even tried 2nd start. Tried 2nd gear only ect. Nothing. It just digs holes in the ground. What am i doing wrong? What settings should i use if i want to go up a steep hill when its either muddy or ice'y? Thnx in advance p.s happy new year every one
