The most non funny clown I've ever seen. He can't possibly say how his engine has improved unless he has done a before and after inspection. What is his definition of "blow by"? Past pistons or valves? The best treatment is a good hard run down the m'way. If it does not improve the only answer is a strip down. His treatment may well be depositing crap on the rings, thereby temporarily making better compression.
Cheers Clive. I'll have a look. I expect you remember one big advantage to the UK when the Mway's opened. No speed limit so you could take your 30mph average daily driver out at 80 mph flat out for 10 miles to try and burn off deposits. It worked on my Mums Morriss Minor which me and a friend borrowed after dark and did this. The exhaust was like a Roman Candle. We were in hysterics of laughter.
The old Moggies A series engine could take a bashing.Cheers Clive. I'll have a look. I expect you remember one big advantage to the UK when the Mway's opened. No speed limit so you could take your 30mph average daily driver out at 80 mph flat out for 10 miles to try and burn off deposits. It worked on my Mums Morriss Minor which me and a friend borrowed after dark and did this. The exhaust was like a Roman Candle. We were in hysterics of laughter.
That's right Chas but not the 803 cc I was cursed with. Big ends went every 5000 miles.
Well frank I'm very tempted to buy this one, it's got a 3.9 Disco V8 engine, jaguar rear axle with LSD and inboard discs and calipers, Gaz coil springs over shocks, front end is Vauxhall Chevette with heavy duty coil springs, all professionally built, but it would probably mean giving up the Cruiser and I'm not sure if I could do that.
One other thing is it's £10000 and in Aberdeen.
