Outhaus rooftent, new
stan
New , ex demo, had on disaplay at a few shows, never used.
Nice small tent
Retail is £1295
Looking for £995 ono
The Leif roof tent is ideal if you need extra sleeping space in your campervan or want to use your vehicle for passengers and storage while sleeping upstairs!
Our roof top tents are used by 4×4 overlanders and adventurers who need a reliable, high quality product that they know they can depend on. The 25mm aluminium internal frame is stronger than others on the market that use a smaller diameter. It provides a robust solution while remaining lightweight. The polycotton canvas is stronger and better insulating than cheaper 100% polyester alternatives.
Leif sleeps 2 on the integrated high density foam mattress. The fully opening no-see-em mesh panels give masses of ventilation and the solid canvas window covers can be closed for privacy and light suppression. The main tent body is made of high quality 300g ripstop polycotton canvas with taped seams, impregnated and PU backed giving superb waterproofing capabilities. The mesh windows and vents give a comfortable night’s sleep and the insulated base combined with the mattress and canvas construction keep you warm on cold nights and cool on hot ones.
Specification is as follows:
Flysheet: 420D Polyester Oxford, PU coated to 3000mm
Body: 300g Rip stop polycotton canvas
Cover: Heavy duty 680g PVC closed with an SBS zipper
Mattress: 60mm thick elastic foam with 500mm 190T polyester cover
Internal frame: 25mm with alloy centre hinge
Zips: High quality SBS
Base: Aluminium/foam sandwich giving superior insulation
Storage: 6 x internal gear pockets
Ladder: Telescopic ladder extending to 2.3m max
Size when open: 1.2 x 2.1m (height approx 1.3m)
Size when closed: 1.25 x 1.1m (height approx 28cm)
Weight: Approx 50kg
The tent is mounted to your roof rack or roof bars using 4 strong universal clamps.
