Portable winch
Chas
This looks a handy bit of kit to complement the main winch for £250.
thats no good its only pulling a quad bike, mine weights nearly 2 ton
from there site
This is the winch you need. At home, on the road, on the trail, at the track, at the boat ramp - anywhere you could use a pull, the Superwinch Winch2Go is ready. Pulling 4,000lbs the Winch2Go has everything you (included!) need to safely pull up to 8,000lbs. See what makes the Winch2Go the smartest choice.
from there site
They supply a snatch block, that'd give you an 8000lb pull should be OK unless you're pulling up a cliff.
For someone with a very occasional use for a winch or just as a 'be prepared' addition to the emergency toolkit I reckon that's a great idea. Sure, no good for serious offroading or HD recovery but that's not what it's aimed at. :thumbup:
Goodwinch have done a "winch in a box" for a while.
