Bruno Oliveira
- May 6, 2019
Hi all,
I have a 97 LC KZJ 90 1KZ-TE and i am currently stuck with it parked in the mechanic not knowing what i should do. One day i was driving it and the engine suddenly died to get back to life just by starting it again normally... Weird, maybe was just a one timer i though... Some days latter, the same happened and it started to happen more frequently until one day it died without coming back to life... I sent the car to the mechanic which told me that it was a problem in the Fuel cutoff solenoid. They repair it and bamm, engine running again as expected, you can get your LC back, no sweat they told me!
I took the car home, but in the next day the engine died again and it restarted with the turning of the key right after... This time however, another symptom started to happen, the engine light sometimes got turned on for a while (a few seconds) and it would turn off again. I check the diagnostics code by myself this time and it was error code 33 - Intake constrictor control signal. Talked to the mechanic again which told me that this could be normal and to wait a few more days to check if it would happen again...
After 2 weeks the engine died again and i could not started so back to the mechanic he went again. After 2 months they can't seem to find the problem with the car which is now on an auto electrician that says that the ECU is damaged since it does not give any neutral signal to the pump and no error codes can be read from it at this point, he says that the light just blinks fast.
Obviously that at this point i don't trust that these guys know what they are doing. They say that the ECU is damaged but i am not even sure that if i buy a used one, if they can install it properly. They say that they have other clients with similar LC, but they can't use their ECU to test on mine because the immobiliser will then get locked and both cars will not run anymore, so i am thinking if i buy a new one, how can they solve my problem? So i am kind of desperate here trying to figure out what to do with my dear LC...
If someone can be kind enough to give me some hints to provide the electrician on how to test if the ECU is really broken or to get the error codes to provide reading again i would be greatly thankful. Also if someone could explain to me what needs to be done to replace the ECU with a used one it would be really helpful as well. I am completely in the dark here.
Many thanks.
Many thanks.
