Power window Regulator
Phantom
malta
Hi all :)
One of the very first issues at hand with my Lj71 is the power window regulator. The window will not go fully up...it clicks as it reaches the top.
On closer inspection, I noticed that the 'teeth' on the power window regulator gear have eroded away and thus the motor does not engage and the window doesn't go fully to the top.
The guy down at the shop told me that I'd need to look for a new one but given the scarcity of these trucks where I live I bet it's not going to be an easy task.
Are you aware whether this part is interchangeable with some other model like hilux or even another brand? Or whether you have any solution for this?
Thank you in advance :D
I had to replace the motor for my LJ70 window as it wasn't taking the window up or down and I am in a similar position as you living on a small island. I found a Toyota Corolla one that matched and is working fine. Pop down to a scrap dealer and see what they have and take your old one with you to match I'm sur you will find a replacement.
Cheers mate thanks :)
I guess that is the best bet I have at this stage
