Welcome Misiek
What modifications are you planning to do?
My Prado is pretty much stock. Only 2 things previous owner did was installing winch and changing stock suspension to Dobinson's +2" coil springs.
For now my plans are:
- steel rims with 265/70r17 BFG's KO2 (this is already ordered and is coming my way)
- all typical maintenance (timing belt, oils, filters, etc.),
- regeneration of torque converter + AT filter and oil,
- adding engine oil catch can,
- reprograming ECU for higher power and better torque distribution,
- minor welding and rust-proofing (somewhere in the future also full frame restoration but for now it's decent),
- recovery points,
- snorkel and diff breathers,
- dividing both stock batteries with isolator and building dual battery system,
- underbody protection for all vitals,
- steel side steps / rock sliders,
- roof rack / overlanding platform (for using with and without a tent) with led lights in all 4 directions,
- 300l/min 10bar air compressor with ~5l tank for inflating tires + (in future) running lockers,
- air-locker(s),
- second fuel tank,
- running water system with a tank, in-line filtration, heat exchanger and 12v pump,
- 270* awning,
- mounts for shovel, hi-lift, recovery boards, etc.
- drawer system with compressor fridge and built-in kitchen.
I don't have any strict plans for when, what order, etc. Most of the things I will figure out as I go.
A lot will depend on how much time and money I have in a moment.
Some plans might change, some might be skipped, some might be added.
You know how it is.
When I start the build I will most probably share it with the forum in a seperate thread.
Cheers!
