- Jun 30, 2011
The suction control valves are a pair, red and green. Not hugely difficult to change, but the area must be scrupulously clean. As for testing I'm not sure even a resistance test will tell you if they work properly as they can work intermittently and then cause the symptoms you describe. As for the autobox stuff, I'm in the dark, as they are witchcraft...
