PZJ-75 Fan belt numbers
CharlesS
philippines
Before leaving the Philippines I documented part numbers for maintenance items to purchase while in the US. I have purchased several replacement filters and a few replacement parts. I have searched online trying to find fan belts for the engine, but the numbers that were on the installed belts do not cross over to anything.
The numbers on the installed belts are: CR 112178 2127 (alt/wtr pump) and C0094 27 63L1 (A/C). The only belt driven items are the water pump, alternator and air conditioning compressor.
I was wondering IF someone that has a 90-93 PZJ-70 (75) engine with A/C, could provide me with the proper belt manufacturer and part numbers for the A/C belt and the Alternator/Water pump belts.
v-belts for the 1PZ seems to be the same as for the 1HZ.
Thank you for the information.
After looking around... I found a website called Toyo.DIY where I searched my VIN and it has a wealth of vehicle and parts number information....
