Rear calliper stainless clip slide thingies
StarCruiser
When I swapped my pads recently, I inspected the rear ones too. With the pads out, I found one of the stainless clips that line the ends where the ears of the pads sit to be inexplicably split in line with where one of the pads goes.
Question is, does anyone know where I can get these on their own or does anyone have some lying around on an old calliper they wouldn’t mind popping in the post for me?
My local motor factor unbelievable had these in stock.
Might be worth trying yours.
Just discovered 3 of mine have vanished. But £18 for 50p’s worth of parts is crazy
Anti squeel/rattle springs. Are they just for 12 valve? My 24 valve has never had any.
Rough Trax Rich, Iv just recently bought some.... Not cheap for what they are , But 3 times cheaper than what Toyota Quoted...... Better off seeing if Mike (Chapel Gate ) has any
Mate send me your address and which one it is and I'll mail you one down no prob.
Got loads of old calipers kicking about.
Thanks all, just ordered some from RT… then saw your post Andy…:doh:Thanks anyway. :)
I had no idea you could buy them separately and that it would be so easy.
