Howmanygoes
- Jan 14, 2019
So decided to try to rebuild my RDL actuator. I ended up acquiring a spare damaged one via eBay.
View media item 2722The old unit had a cracked casing and the cover plate I’ll fitting (8-10mm gap ( see red ringed areas)
Internally it was filled....
View media item 2710
After drilling out the screws and cleaning the drive gears, the gears in the old unit were undamaged. The faulty eBay unit had broken bushes and a damaged drive wheel. The bushes in the old unit were also ok.
View media item 2714Damaged drive wheel
So bushes swapped and drive wheel swapped
View media item 2713View media item 2712
Tape was just to retain the sprung bushes until the rotor was refitted
Reassembly almost complete
View media item 2715
Finally inserted the pin and tensioned using rotor. (Not sure if this is right)
And done
View media item 2718
On bench testing (blue red and blue wires) motor drives and pin comes out and in... result as funnily enough it didn’t work before (broken bushes and the old one never would). However on connection the the wiring loom, nothing, zip, nada....
Out with tester.
View media item 2720.View media item 2719CDL engaged (box in low) (CDL doesn’t engage when I push the button in High... confused ) orange light on dash shows engagement.
Put tester to blue and blue red inputs in the socket pictured. And turned RDL switch nothing on meter but abs light and second red flashing RDL light comes on....
Any advice where to go next, I also can’t find the fuse box on the RHS... to find the 20a fuse,
And done
Out with tester.
