rear springs
Higgy Mar 13, 2018
  1. Higgy
    Higgy Well-Known Member I am in denmark
    465
    226
    43
    Map
    Hello to all. im newish to the forum and could do with some advice. I decided to change my rear springs (lwb Colorado) 21 yrs overdue I think.. the inner rubber dampers were totally shot and the steel ring where the spring sits in the top also rusted to bits. is it possible to buy the damper as a complete piece or is possible to fit the new springs without the inner damper.. hope this makes sense ... any advice.. many thanks..Higgy
  2. Shayne
    Shayne Well-Known Member Guru
    10,403
    2,770
    113
    Map
  3. Shayne
    10,403
    2,770
    113
    Map
  4. Higgy
    465
    226
    43
    Map
    Hi Shayne. thanks for the reply. the top and bottom where the spring sits is fine its the steel rim that's attached to the rubber bump stop that sits at the top of the spring is shot (my mistake not damper)...thanks for the info at least I know I can get hold of some.. would you recommend milners or roughtrax for springs? im just after a standard pair HD.. Many thanks
  5. Shayne
    10,403
    2,770
    113
    Map
    I get all my stuff from Roughtrax , my bumpstops have no steel ring on top , i can only guess your talking about a metal spacer kind of thing ?
    Unless you do extreme off road or carry silly weight in your truck the bumpstops serve no purpose at all really .
  6. AndycruiserguyLomas
    3,475
    796
    113
    Map
    Welcome aboard Higgy. IMO as a Collie owner I'd say for ride quality you can't beat OEM springs and dampers.
    Others may say different but on a predominantly road queen Mr T knows best.
  7. Higgy
    465
    226
    43
    Map
    The ones I took off had a steel rim with a lip that sat on the top of the spring before you fitted it in place it all seemed to be part of the rubber stop. maybe il do away with them and just fit some decent springs.. cant find any at milner or roughtrax are they dealer only part.. thanks anyway Shane
  8. Higgy
    465
    226
    43
    Map
    Cheers for that mate.. il get some pricing up done.. thanks
  9. Shayne
    10,403
    2,770
    113
    Map
    The Monroe i put on the KDJ90 are good and comfortable but there not the same Roughtrax sell now i don't think .
Share This Page
    Dismiss Notice
