MarkW
- Aug 20, 2014
Whilst fitting new ARB bushes I noticed that my near side shock was moving in the top mount. Having taken the shock off it looks like there is some wear on the hole the shock mounts through.
Anyone know what size this hole is supposed to be? the pin on the top of the shock is 10mm but the bush that sit below has a flange that I assume sits inside the hole. 12mm looks like it might be a little tight so could the hole be 14mm?
Bush looks like this
