Hi Steve, if you have another read through this thread there’s plenty of good info from Bob. The fuel lines can be changed without taking the body off but you will need to drop the tank, especially as you have replacement steel pipes, it’s a tight fit between the chassis , prop shaft and exhaust so it’s really a two man job. While you’re at it check the filler pipe for corrosion, that’s also a tight fit but it can be changedwith the body in situ.
Good luck with it
Good luck with it
