Resirc/Fresh air button stuck on Fresh
cHRNO
sweden
Hi all,
Having some problems with my aircon.
One of them being that the Resirc/Fresh air button is stuck on Fresh. It does not go off/change when I press it and nothing happens with the servo.
My conclusion is that it has something to do with the servo motor, since a fuse problem ought to take out the diode/lamp pointing out that it's set to fresh. Is this assumption correct?
My next step as per the manual would be to test the motor by plugging it straight to the battery. Should I do this whilst it's mounted or should I take it out first?
Thank you very much in advance.
Quick update on this. The Aircon controller seems to be a tad tired as pushing the button furiously for a couple of seconds changes the mode from circ to recirc. Same with the AC button even though I have troubleshooted the AC and found out the compressor is broken. Well, glad I found out the fault, and I am sure a bit of cleaning of the button/switch will be enough to get it alive and kicking!
